Results 1 to 7 of 7
Thread: Disc brake conversion part numbers
Threaded View
Previous Post Previous Post   Next Post Next Post
  1. #1
    Geek in Residence 67440Dodge's Avatar
    Join Date
    Jan 2013
    Location
    New Joisey
    Posts
    2,257
    If you've done the A/M body disk brake conversion on your car (or manage to get yourself a hold of a set of spindles/brackets), and the parts store doesn't list the parts anymore, here's some part numbers to help them cross reference:
    All are Bendix part numbers unless otherwise specified
    Calipers: Raybestos FRC2067 (left) and Raybestos FRC2068 (right) (if you or someone moved the calipers to the rear to allow for a sway bar, then swap the numbers accordingly)
    Rotors: 14115
    Bearings: Inner: BCA A17 Outer: BCA A2 Seal: 5121
    Master Cylinder: 11627 (This is a manual brake MC for a police car. It has the same spec's as the Mopar Performance MC).
    Brake Pads: MKD84 (OEM on the police cars.. only difference between this and regular pad is it's semi-metallic.
    Proportioning valve: Used a Wilwood adjustable. They weren't re-popping the OEM style valves back then.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
