Results 1 to 7 of 7
Thread: Metal brake with a press
Threaded View
Previous Post Previous Post   Next Post Next Post
  1. #1
    I was the first... 67r/t4speeder's Avatar
    Join Date
    Jan 2013
    Location
    Caldwell, Idaho
    Posts
    6,079
    I needed some 3/16 X 3.5 wide steel to bend a 90 and do not have a brake for this so I tried using the press with some angle iron, I put the rod in middle because the angle iron was bending flat and it helped long enough to get the job done. It worked well I think.
    Attached Images Attached Images
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
