Results 1 to 1 of 1
Thread: 70 Coronet 426/440-4 BBl 4 Door
Threaded View
Previous Post Previous Post   Next Post Next Post
  1. #1
    Junior Member
    Join Date
    May 2015
    Posts
    2
    REDUCING PRICE The car was set up for Drag Racing, On Weld Wheels with HOOSIER 31/14/15's and M/T ET tires.
    Car has been rewired with Head, Tail & Turn Lights for street use. On Rocket Wheels with Firestone Cheater
    Slicks and RWL Firestone's up Front.
    Fresh rebuild on motor, has only 115 miles on it.
    ENGINE- Block was NDT'd, no issues found.Rated at 651 HP & 625 FP Torque.
    BLOCK- Iron 426 Hemi, Part # 2468330-M. I LEARNED THAT WHEN NASCAR OUTLAWED THE HEMI, CHRYSLER ADAPTED THE 440 HEADS TO THE HEMI BLOCK. PETTY RAN ONE OF THESE ENGINES.
    CRANK-RB & Hemi 4015" Stroke Balanced.
    FLEX PLATE- Mopar CFI RB & Hemi 8 Bolt Holes.
    RODS- Manley Sportsmaster I Beam.
    PISTONS- Custom JE with Custom Sizing File Cut Molly Rings, 12.4:1 Compression.
    CAM- Lunati Solid Roller #LUN-53701.
    HEADS- Indy 440 Aluminum. NDT'd & Pressure Tested Before Rebuild.
    MANIFOLD- Mopar Single Plane.
    CARB- Proform 950 cfm. Holly Fuel Pump w/Filter.
    IGNITION- MSD w/MSD Digital-6 Plus 6520.
    WATER PUMP- Electric w/ Duel Electric Radiator Fans.
    TAC & GAUGES- Tac- Auto Meter- Sports-Comp w/Memory. Speedometer, Oil Pres. Water Temp.
    HEADERS- Headman Husler w/Doug's Headers Electric Cut-Outs.
    MUFFLERS- Flowmaster's.
    TRANSMISSION- 727/904 Pro-Trans. Trans went to Pro-Trans for overhaul, no issues found.
    TRANS Oil Cooler w/Filter.
    TORQUE CONVERTER- Hughes Performance. Was Over-Hauled, New Parts As Required.
    SHIFTIER- Cheetah SCS w/Line Lock & Trans Brake.
    AIR SHIFTING- Dedenbear Model AB1OK w/RPM Switch Model RPM-2.
    ROLL CAGE- Certified 8 Point.
    REAR END- Dana 60 w/Moser Engineering Center Section. 4:30 Gears, Posie.
    AXLES-Strange Engineering.
    BRAKES-11" Drums.
    SHOCKS- Strange Eng. Double Adjustable Aluminum.
    UPPER BALL JOINTS- New.
    TRACTION BARS- CalTracs.
    Car is in Fallon NV
    The 4 Doors may turn you off, but look beyond that. See what is in and under the car. Every thing can go into an "A", "B" or "E" body. There is $18,000 in the motor alone. The car has been apprised by Hagerty at $42,000. It has run in the 10.80's at 126 mph. You have a start of an early 426 HEMI.
    Asking $20,000.00 Call or text me at 623-229-1821 e-mail at psadler47@gmail.com I WELCOME ANY REASONABLE OFFER, THANK YOU
    Attached Images Attached Images
Posting Permissions
  • You may not post replies
  • You may not edit your posts
