Results 1 to 4 of 4
Thread: Modern type headliner
Threaded View
Previous Post Previous Post   Next Post Next Post
  1. #1
    Senior Member RT K_line's Avatar
    Join Date
    Aug 2015
    Posts
    253
    I have installed a modern type headliner on my R/T. I used a sheet of corplast to do it. About $10.00 a sheet. I had already installed some insulation in between the supports. Temp dropped 15 degrees with the insulation in direct sunlight. Now it has a modern look. Corplast is basically a plastic cardboard structure. I just used yellow weather stripping adhesive to glue it to the Inslation. I also used my light from my 95 nissan hardbody pickup for the interior light. I like how it came out. Here are some pictures.
    Attached Images Attached Images
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
