Results 1 to 6 of 6
Thread: Mystery switch
Hybrid View
Previous Post Previous Post   Next Post Next Post
  1. #1
    Senior Member 50net's Avatar
    Join Date
    Jan 2013
    Location
    La
    Posts
    101
    Mystery switch
    I have one of" those" questions maybe someone has the answer.while under my car measuring the brake lines i came across a line block right before the rear soft brake line that connects to the T on axle,that has a round switch ontop with 2 wires going up thru wheel well.What Is It?i ve checked my repair manual & the net, did not find.i know cant be a brake pressure switch ??
  2. #2
    Join Date
    Jan 2013
    Location
    La
    Posts
    101
    Well after some more research, is that the brake light switch? It works off pressure in the line?
  3. #3
    Senior Member Drag-Net's Avatar
    Join Date
    Jan 2013
    Location
    S.E. Pennsylvania
    Posts
    414
    Unplug it and jump it out and see if the brake lights come on.....
  4. #4
    Join Date
    Jan 2013
    Location
    La
    Posts
    101
    Good idea.worth a try.was hopeing someone was familiar with it
  5. #5
    Member roadworthy's Avatar
    Join Date
    Jan 2013
    Location
    St. Louis MO
    Posts
    90
    2 years later, yes it's the brake switch. sorry I haven't logged in for a while
    I stopped fighting my inner demons. We're on the same side now.
  6. #6
    Join Date
    Jan 2013
    Location
    La
    Posts
    101
    Quote Originally Posted by roadworthy View Post
    thanks I figured it out back then,havent been on for awhile either,LIFE getting in the way
Posting Permissions
  • You may not post replies
  • You may not edit your posts
