Results 1 to 1 of 1
Thread: 1966 coronet 2-door 383 fresh restoration
Threaded View
Previous Post Previous Post   Next Post Next Post
  1. #1
    Junior Member
    Join Date
    Apr 2014
    Posts
    3
    selling for a friend... (not just any friend...this guy has done meticulous work to finish my last project. he is a fanatic about paint and body lines and door closings and fit and finish..etc..)
    this is a fresh restoration of a very clean southern 1966 coronet.
    car has been been detailed and finished in a very clean and nice way. the custom made interior has a totally luxurious look and feel that is more plush and eye catching than the original style. this gives it a stepped up modern type feel. very clean as the pics show, very fresh.
    the body and incredibly nice frame of the car are super..you could take this to any local show and be very confident of getting rave reviews..again, quality and clean build by a mopar master of his craft who cares about his work. please note the photobucket pics below and the clean trunk with original jack and spare. also note the clean trim on this car.
    the 383 two barrel engine and 727 big block trans are a great running pair taken from a wrecked 99,000 mile newport. they both have been freshened, motor with new rear main seal, new valve seals, fuel pump, water pump and gaskets, and the fine shifting trans which had bright red fluid when drained also has fresh fluid for good measure. rear end has new axle seals and lube and is a 323 open. the car has been driven on the road smoothly at 70 mph and it runs cool due to the brand new aluminum radiator that is a three core.
    all new brake lines and fuel lines....gas tank and sender are new also and the sender does read the proper level in the gas tank..car has new brakes and drums and will give you the confidence to stop as well as you start. and she will handle well as the front end has been rebuilt.
    outstanding looking detailed grille and the rims are very well restored and the tires are ready to roll as well..this is a car you can get in and drive home..
    turn key cruiser and local show car.
    here is a link to about 50 pictures that will back up what i am saying about the quality of the car.
    super yellow 66 coronet
    price is $18,900 OBO
    text preferred or call 440-522-0048
    car located near elyria ohio just west of cleveland ohio..
    transport can be arranged with prior payment and we will help load as well.
    no way you could build the car for that and you can just jump in and enjoy this one without years of working on it.
    Attached Images Attached Images
Posting Permissions
  • You may not post replies
  • You may not edit your posts
