Page 11 of 11 FirstFirst ... 91011
Results 101 to 103 of 103
Thread: New bullet for the "Brick"
  1. #101
    What's a stroker? theman440's Avatar
    Join Date
    Jan 2013
    Location
    Las Vegas
    Posts
    1,260
    Quote Originally Posted by markz View Post
    My favorite valve covers.
    What heads do you run? I machine spacers for those valve covers and o-ring the head to spacer. It works out real nice - never had any leak. But not all heads are the same. I'm in the process of making another run. Ordering material next week. I can make an extra set if you have any interest. Around $50 - 60 in material.
    The other thing I do with those covers is machine the baffle standoffs some and safety wire the screws so that they can't fall out.
    I am running Indy EZ heads, but at this point I'm not sure if I will use the Mickeys or not. I am still interested in the spacers though.
  2. #102
    Join Date
    Jan 2013
    Location
    Las Vegas
    Posts
    1,260
    While I wait for machine work I got back to refurbishing the passenger door. Disassemble, vacuum, clean, wax inside of door. Clean & lube regulator, replace glass channel glides. Could have finished but the new cat whiskers don't fit right. Called the supplier - hope fully something will get worked out.
    IMG_20191006_144245020.jpgIMG_20191006_144239152.jpgIMG_20191006_152625761.jpgIMG_20191006_174710229.jpgIMG_20191006_192800211.jpg
  3. #103
    Join Date
    Jan 2013
    Location
    Las Vegas
    Posts
    1,260
    Another issue I wanted to address - the arm rest pads interfered with the roll cage so I had to remove them. There was nothing to grab on to close the doors, so I would pull on the window crank or wind wing latch - no more.
    I painted the base (supposed to be chrome but close enough) made this plate with the same profile as the armrest pad, painted it wrinkle black.
    Now there is something to pull on to close the door.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
