Results 1 to 9 of 9
Thread: Made a fan shroud
Threaded View
Previous Post Previous Post   Next Post Next Post
  1. #1
    Senior Member Mark's 69's Avatar
    Join Date
    Jan 2013
    Location
    St. Marys, PA
    Posts
    464
    Made a fan shroud
    I got the idea from one of those Power Block show a while back when they made an air dam for an autocross truck. I made up a jig from some scrap wood, built the frame, and stretched a $2.50 fleece throw over it. This was my third attempt so I learned the jig and sewing the fleece in place worked best for me. Then I laid the fiberglass resin to it. Some sanding , a little bit of bondo to smooth it out , more sanding and a coat of paint and it's done.
    I never really had overheating problems until they opened up the local airport for drag racing, then it got hot in the staging lanes. The radiator is a Summit universal fit so I was having trouble finding a shroud that I liked.
    Attached Images Attached Images
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
