Senior Member
Fuel gauge
I have a question to throw out there.i recently replaced fuel tank with new sender.gas gauge didnt work prior was hoping new sender would correct.well heres the question i read that the sender needs to be grounded, but...as the old the new sender has a rubber seal between it and the tank so how does it ground thanks in advance because i know someone has the answer
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
