Results 1 to 8 of 8
Thread: 1967 Front End Work
  1. #1
    1967 Front End Work
    I need to start work on the front end in stages. What would be the first step? Upper and Lower ball joints? Thanks.
  2. #2
    What's a stroker? theman440's Avatar
    Join Date
    Jan 2013
    Location
    Las Vegas
    Posts
    1,389
    Id go lower ball joints, strut bushings and lower control arm bushings first. Then second upper ball joints and upper control arm bushings.
  3. #3
    I was the first... 67r/t4speeder's Avatar
    Join Date
    Jan 2013
    Location
    Caldwell, Idaho
    Posts
    6,244
    Have you had an inspection done?
    Jeff is right start down low and work your way up. Only replace it if needed though.
    No inspection, just wobble and tire scalloping. Just had a tire balance and same thing still happening. This very helpful. Thank you.
  5. #5
    Geek in Residence 67440Dodge's Avatar
    Join Date
    Jan 2013
    Location
    New Joisey
    Posts
    2,476
    Just don't buy one of those all in one kits from Kanters/PST/Just Suspension.. cheaply made Chinese/Taiwanese parts that last as long as old fuel line and ethanol. Moog parts are still available, I've got a list of part numbers on the site to use.
    If you're scalloping I'd look at shocks as well..
  6. #6
    Where would I find that list 67440?
  7. #7
    Senior Member Mopars & Missiles's Avatar
    Join Date
    Jan 2013
    Location
    Northern Indiana
    Posts
    155
    Quote Originally Posted by stonehengeheels View Post
    https://www.dodgecoronet.com/coronet...spension-Parts
  8. #8
    Join Date
    Jan 2013
    Location
    New Joisey
    Posts
    2,476
    Quote Originally Posted by Mopars & Missiles View Post
    Thanks!! If your local auto parts store can't get them, believe it or not Amazon used to carry them.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
