Disc brake conversion help!
5987The parts store didn't have any C body lines in stock so I was digging through the lines they had. I think I have something that will work. I've been working on a 69 big block camaro for last 2 months for a guy and just installed the same type of rubber lines Mike described. It for a 69 big block Camaro. I'll install everything on Friday and keep you posted.
Installed the Camaro brake line on my brothers road runner. It looks like it will work o.k. Now I just have to reinstall the oil pan, install new headers, make a fan shroud, replace the motor mounts, adjust the valve, and install a new interior. Hopefully he will drive it after this. He's had the car for 25 years and only drove it about 500 miles! He won't have any excuses not to drive it when I'm done.
It has been a while since I did mine, but I think it said something about switching side for front or rear caliper hose mounting. Mine was not a Right Stuff Package, I found a factory parts kit, for a wear replacement situation standpoint.
I did a right stuff conversion on my 69. I'll see if I can take some pics. I didn't have any issues with the brake lines. I had a problem with the brake booster fitting. Have you done the booster yet?
Last Post: herklots
