Can a bad pump cause this condition?
Hibbing_Coronet_500 Wrote:Update:
loose or worn inner or outer tie rod ends? NOPE!
Upper and lower ball joints. NOPE!
Loose and worn inner and outer tie rod adjuster BARREL. Yup!!
All Is tight, yet it slops on the threads, Causing alot of defelection..
It even clunks once you know its there...
That sounds dangerous. I've never seen the sleeve slip before. Had my pitman arm loosen on my big truck this winter, but never seen that before. Glad you found it.
  Power Steering Pump ID 67440Dodge 1 3,456 05-19-16, 10:57 PM
Last Post: Drag-Net
  Mancini Water Pump housings 67440Dodge 5 4,577 10-04-15, 06:57 PM
  Power steering lines and pump Jpr777 7 4,436 09-25-15, 01:59 PM
  Power steering pump Lipers1 2 2,641 09-08-15, 10:39 AM
Last Post: Lipers1
  Power steering pump Lipers1 3 3,211 09-01-15, 11:38 PM
  Trying to figure out ps pump. ws27 13 8,629 07-05-14, 12:13 AM
  can't find window washer pump wire on 1967 coronet 440 boydsdodge 9 6,417 05-22-13, 07:37 PM
