Holley Tuning
Its a new carb, I just tried bringing the plates all the way to the open position (with a feeler gauge I am talking like .025....and she wont start.) I am running an MSD billet distributor now
think its a matter of tune tune tune till I find the sweet spot
Kevin, I agree with Joe, I bet you need to drill some holes in the primary plates. Only problem is how big?
Maybe start small, then go up as needed?
Drilling is basically a controlled vacuum leak. So before you start drilling, reset the carb to factory settings (plates just exposing the idle circuit, idle screws turned out a bit) and then start it with a vacuum hose that attaches below the throttle plate removed (good one is the 3/8 one in the back). Start closing off the hole with paper until it starts to run decent. if it won't run decent with this vacuum leak, then drilling won't help.
  Holley 750 double pumper question honcho 11 7,742 02-23-13, 11:44 AM
