Clutch pedal return spring
The instructions for a Centerforce diaphragm type clutch state that you should not use a clutch pedal return spring with this type of clutch. Which spring are they talking about?
1. The large over-center spring inside the car or...
2. The smaller spring that runs from the bell housing to the fork.
The large over center one inside.
If you don't remove the over center spring, the clutch pedal will stick to the floor at higher RPM's. I found out first hand!
It's not all that easy to remove IIRC.
Thanks guys. I thought that the heavy one inside is what they meant, but I just wanted to be sure.
4264door Wrote:It's not all that easy to remove IIRC.
Not too hard - depress the pedal and put shims between the coils and it will slip right off.
Mark has some great tips, thankyou Mark
  Spring Carlisle 67440Dodge 24 25,507 08-09-20, 10:23 PM
  Spring Fling theman440 9 21,257 04-16-19, 03:07 PM
  It's Spring! OldSkool 6 4,219 05-04-15, 05:26 PM
Last Post: 4264door
  does a 1969 a12 (440 six pack) car have a fan clutch? Warhawkfight34 12 7,796 06-26-14, 02:38 PM
  Brake pedal assembly? Warhawkfight34 1 2,517 04-17-14, 05:32 PM
  To celebrate spring I took her out and washed her and too GREAT pics!! Warhawkfight34 6 5,071 04-08-14, 10:16 AM
