Rear leaf springs. Gotta get rid of air shocks!
Good day gang.
Not much new with my 67. Had not driven it in over a month. I noticed last night that the air shocks went flat.
I noticed that the car has a bad sag on the drivers side.
Also I can't believe how low it sits with the shocks gone flat!
It's time for springs! I want the springs to support the car and give proper ride height without air shocks!
Buy new? Or have mine rearched?
I don't want that hot rod rake. Just that cool look with the wheel rim exposed
Have any of you folks gone down this road?
Thanks tons
Joe
Espo's Springs and Things in PA is good to deal with. They'll customize the springs to whatever lift above stock you want.
Just my personal experience.. avoid the Mopar Performance springs. Lots of people (including myself) had issues with them sagging after about a year.
I would have you old ones fixed up. Good metal
Thanks for the tip. My springs are MP springs that the old owner put on at one time.
I've purchased new rear springs from St. Louis Spring Co. for our '64 Belvedere and '71 Charger. Good prices and reasonable delivery charges. The Belvedere had air shocks, that's why I replaced them. I had them built with 6 leaves each and had 2" of extra arch in the springs. The car set even higher in the rear then with the air shocks fully extended. If I had it to do over again, I'd just put 1" of additional arch in the springs.
Wow! Thanks for the info. You know exactly what I'm after!
Thanks tons!
Histoy.
In all my excitement . Did you custom order from scratch? Or a catalog? Part number? Or re man your old ones?
In short.... How would I order mine using your advise.
I just called them direct and discussed it with their sales rep. He's the one that suggested I go with the 6 leaf springs like they used in the station wagons that year. I had a 426 Max Wedge engine and that stiffened up the rear very well, but you'll likely want to stay with the 5 leaves. I also recommend that you order the rubber bushings directly from them.
3126 Samuel Shepard Dr.
St. Louis, MO 63103
(314) 533-2132
Thank you so much!
Caltracs Monoleafs are nice too, and you can order them in stock, 2 inches low or 2 inches high. Nice ride and very light.
  Rear Wheel/Tire Size Advice MrV8JF 1 227 05-15-23, 09:36 AM
Last Post: revel68
  Rear Main Seal-Opinions wanted 67RTBlue 19 28,230 08-21-18, 09:49 AM
  Widest tire that will fit on rear of a 67? 67RTBlue 4 5,470 11-12-16, 10:58 AM
  Adding rear speaker/speakers to a stock radio? 67RTBlue 3 3,425 08-16-15, 02:31 AM
  70 Coronet E-Brake Springs? blownNinjected 2 3,282 06-05-15, 07:07 PM
Last Post: blownNinjected
  Rear axle wheel bearings Dionisio -C- 6 4,642 02-22-15, 08:07 PM
Last Post: Dionisio -C-
  Rear Sway bars on a WAGON??? rolling18 8 6,066 02-14-15, 02:15 PM
