Need help keeping the Throttle Level attached to the Throttle Body, On a 1952 Dodge Coronet
As the Title says, I have a 1952 Dodge Coronet with Gyromatic Transmission. The car normally runs great, however during operation of the car the Throttle Lever (lever) will become detached from the Throttle Body(Assembly).
The lever is attached to the assembly by a rectangular pin that protrudes from one side of the assembly (might be the Throttle Stop Pin). The lever articulates in a back and forth motion pulled by a rod that is attached through a series of parts which ultimately connects to the gas pedal. I can reattach the lever, however after a few minuets of operation the lever will become detached. I have attached some images.
Has anyone had this issue before? Can I replace the throttle body? Does anyone know a replacement part that would fit?
I believe the part # you are looking for is 1539 149.
I've sent you an email.
  Rear axle replacement for '58 dodge coronet acer 3 20 06-06-24, 02:15 PM
  '58 Coronet Windshield Wipers acer 1 29,589 06-09-20, 03:41 PM
  1956 Dodge Coronet Parts for Sale higbull 0 29,969 07-20-18, 03:14 PM
Last Post: higbull
  '49 Dodge Emergency Brake (Parking Brake) Handle 50Coronet 1 9,204 10-09-17, 03:13 PM
  1/18 scale Coronet Club Coupe Jim 68cuda 0 12,244 06-09-17, 04:20 PM
Last Post: Jim 68cuda
  Original fuel line 50 dodge 50net 3 17,832 04-03-17, 01:06 PM
  Wiring: Accessibility at 1950 coronet crnet50s 1 13,757 01-03-17, 10:36 PM
  1954 DODGE ROYAL FUEL TANK SENDING UNIT... PART NUMBER ? onebad54 10 18,318 05-05-16, 12:49 PM
Last Post: onebad54
  50 coronet wont start 50net 18 21,343 09-27-15, 08:46 PM
Last Post: 50net
  1958 Coronet Wheel offset? samdjr74 0 3,956 08-04-15, 11:49 AM
Last Post: samdjr74
