Back to square one.
Well I thought I had the center carb fixed! But apparently I didn't. Luckly I called Holley direct and they sent me a brand new metering block. I almost SHIAT when he told me it was only $54.98!!! I'll take 2. If this doesn't fix it I am leaning towards vapor lock. But that is worst case scenareo! I guess I will find out tomorrow. Stay tuned!
I wait with bated breath!
Has anyone ever had vapor lock?
What is the car doing? And can you get it to Waltham?
I found out that I was wrong!! (typical me). I told the guys making the final connections that there was not supposed to have
intake manifold gaskets. WELL I WAS WRONG!! SO what is it? A huge vacuum leak. I'm dumb. I bought some edelbrock 7225
gaskets and will have it fixed hopefully next weeke when they come in.
Oops! You can test for vacuum leaks using carb cleaner slowly sprayed around the gasketing surface.
ws27 Wrote:Oops! You can test for vacuum leaks using carb cleaner slowly sprayed around the gasketing surface.
Yup thats what I did. It was bad all around the manifold! No wonder it ran like shiat!
  Dial back timing lights 67440Dodge 3 1,771 08-08-21, 09:25 PM
  I'm back! 67440Dodge 22 25,548 03-13-21, 01:10 AM
  Bring paint back (even if temporary) Piper 28 26,296 07-16-19, 05:50 PM
  back after a long time rp23g7 14 7,582 12-20-17, 03:47 PM
Last Post: rp23g7
  Back up lights Red 67 4 4,088 11-12-16, 10:47 AM
  want to put factory radio back in my car uncledon 23 10,258 05-29-14, 06:51 AM
Last Post: mrconvertible
  Just back From Daytona, and RPDE rp23g7 3 3,607 11-13-13, 10:32 PM
  Got my Car Back Today - Alterkation Front End markz 11 8,505 07-26-13, 11:24 PM
  The Car is BACK! markbob@ameritech.net 3 3,440 05-08-13, 10:38 PM
  I found my way back guys !!!! beefman 8 6,322 01-08-13, 11:38 PM
Last Post: 4264door
