Windscreen washer
Hi, can anyone post pics or a diagram of the setup from washer bottle to the screen for a 68 R/T? Particularly how the nozzles go through the grille
Here are before and after pics of the sprayer. The picture before it is in the grill hole shows it in the same position it is in after it is put in the grill. I will get you the rest of the info soon.
Here are pics
Fantastic work again Mike. Any more detail on bottle and hose setup would be great!
I can't seem to find the hoses for my car at the moment (still looking). Basically separate hoses come off the 2 squirters and run to the passenger side of the cowl. These 2 hoses connect to a tee (a 2 into 1 hose connector). One hose coming from the tee runs along the fender to the pump attached to the resevoir. The resevoir is held in place by 2 screws. It is located on top of the passenger wheel well near the radiator support. I hope I haven't confused you with the passenger side description. I am assuming your car is a left hand drive. When (if) I find the hoses I will post pics.
Thanks Mike, the info is all good. Yes mine is left hand drive, came from Pomona.
Here are pics of the components. The 2 pieces of hose attached to the sprayers are 70 cm and 10 cm long. The hose going from the tee to the pump is 90cm long. It is a little bigger in diameter than the other 2. Tomorrow I'll post a pic of it on the car.
Here you go. Any questions just ask.
Fantastic Mike, that's just what I needed. Now I can get to it and know that I'm setting it up correctly. Thanks again!!
Here is a page from the FSM that might be helpful to you.
  washer switch removal on 67 BooBoo 1 2,494 04-27-17, 06:26 PM
  Washer bottle installed OldSkool 6 3,405 10-17-15, 11:53 AM
  Washer Bottle question OldSkool 9 4,355 10-09-15, 11:26 AM
  Need 67 washer bottle and pump BooBoo 3 3,517 12-21-13, 11:33 AM
