Has anyone added a brake booster to their car.
Hi I have a 67 coronet with disc fronts drum rears and no power booster.
im looking at buying one, any suggestions to where to get them, what brands what size.
anything technical I need to know.
thankyou.
Factory style B-body power brake boosters will require you to either get the firewall plate off a power brake car, or modify your existing one.
I believe theman440 put a A-body booster on his car, hopefully he can chime in and say if any modifications were needed to put it on his car.
If you want to go with a factory style one, then you should get a used one off a car with all the correct hardware. That's the easiest way.
Thanks for that, it's hard over here in Australia to get parts as there are no spare coronets
  Brake pedal ratio 67440Dodge 5 20 10-27-25, 08:09 PM
  bolt pattern power booster mopar440 2 979 05-11-22, 07:59 PM
  '55 Dodge brake drums dodge55 2 21,712 11-04-18, 12:08 AM
Last Post: herklots
  Brake drums from Classic industries Hibbing_Coronet_500 4 4,382 04-12-17, 11:51 PM
  Brake warning light stays on 67RTBlue 7 5,610 06-10-16, 08:55 PM
  Is the firewall different on a factory power brake car? 67RTBlue 2 3,379 04-07-16, 07:57 PM
