Oil filters for 383
Hi all,
as I'm in aus. I cannot find a replacement oil filter for my 383ci as this engine was not standard in aus.
it has a pz1 pennzoil filter on it, and I am needing to change the oil,
what different brands and filter numbers can I use or do you use, everything I buy needs to be online which can get annoying.
cheers.
Also what weight of oil is good the climate I live in is close to that in Miami.
The filter is the same as a wix 51515, Fram ph8a. Not sure if numbers are the same in your country. Also it's the same as what Fords used in the 60s and 70s
I'd go with 10-40 if you can find it there.
Others might have a different idea.
I use the Fram PH8A on my 383. Also the Fram HP1 works. I would suspect that your Penz filter is a high performance filter like the Fram HP1.
These filters are easy to come by in the States.
If I was you? Google the application for your engine. Then research the brand you like based on quality and $$. Then order up a batch of them online.
You can all so use a fl-1a Motorcraft filter
67 R/T 440ci 4spd
[SIGPIC][/SIGPIC]
Also K & N.
wix too!!!
Yeah wix are the filter of choice in the UK.
Who uses what on here and for what reasons? Price, quality, availability, what's on the shelf?
Purolator for my daily drivers. Napa/Wix for the Coronet (bought a bunch and haven't used em all up yet).
K&N and Mopar filters on the Coronet and convert, Fram Extra Guard on the van.
