Has anyone Added an in tank fuel pump For carby setup instead of standard electric
Has any one ran an in tank fuel pump in their cars to their carbys.
the issue I have is that I cannot have the holley electric fuel pump gravity fed as the fuel tank pick up is on top of the tank.
so I was wondering what have people done with this situation.
cheers
Almost all in tank fuel pumps are designed for EFI systems, so you need to do some special configuration with regulators to get the pressure down that a carb can use.
Most add a sump to the bottom of the tank and run the fuel lines off that.
My holley elec. pump is on the inside of my pass. side frame rail down low by the front spring hanger, using a stock 3/8 pick up / sending unit in the tank.
It's worked perfectly fine for the last 15 years.
It is noisy........
interesting would you be able to provide a photo for me please
Drag-Net Wrote:My holley elec. pump is on the inside of my pass. side frame rail down low by the front spring hanger, using a stock 3/8 pick up / sending unit in the tank.
It is noisy........
This is what I did. It probably will be for sale at some time................
7276]
I hope this is helpful.
  Worn Fuel Pump Pushrod 67RTBlue 3 18,365 09-05-18, 09:09 AM
  Fuel tank vents Stargazer 11 8,084 08-04-16, 10:28 PM
Last Post: metaldad
  Electric exhaust dumps-opinions, thoughts? 67RTBlue 3 3,984 07-03-16, 11:30 AM
Last Post: Drag-Net
  Fuel tank to fuel line rubber hose picture 67RTBlue 12 6,972 01-27-16, 02:25 PM
  Fuel filler leaking cnmsales 5 4,006 12-18-15, 06:01 PM
  Mancini Water Pump housings 67440Dodge 5 4,577 10-04-15, 06:57 PM
  Power steering lines and pump Jpr777 7 4,436 09-25-15, 01:59 PM
  383 with a/c pulleys to non a/c setup Jpr777 3 3,243 09-20-15, 07:45 PM
Last Post: Jpr777
  Power steering pump Lipers1 2 2,641 09-08-15, 10:39 AM
Last Post: Lipers1
