slant 6 to overdrive trans adapter
Hi, i wasjust wondering if anyone knows of an overdrive automatic transmission that will bolt to the /6 engine or if someone makes an adapter for a late model upgrade? Doesn't necessarily have to be a mopar trans. Looking for overdrive if possible. Thank in advance for any information.
I don't know of an adapter made for a slant. A gear vendors OD unit might be the only option? It bolts to the tail shaft of the trans.
Thanks 65rbdodge
Might want to give Wilcap a call. According to their website, they have an adapter for the Flathead 6 to bolt up to a GM trans (TH350-700R4), but the downloads page also lists it as available for a slant 6
http://www.wilcap.com/downloads.html
Why stay with the auto? Convert it to a 4 spd overdrive. They were available in a bunch of light duty applications.
67440Dodge Wrote:Might want to give Wilcap a call. According to their website, they have an adapter for the Flathead 6 to bolt up to a GM trans (TH350-700R4), but the downloads page also lists it as available for a slant 6
Wilcap is the place to get it done right. If you need help RT K line there shop is right next door to mine , ask for Pat
Thanks Andy, just thinking of another project for down the road. I have an 87 Ramcharger and a low milage /6 and was thinking of putting them together if I could get an overdrive to work. I like the Ramcharger but the 318 has got to go. 9 to 11 mpgs doesn't work for me as I drive 50+ miles a day round trip.
RT K_line Wrote:Thanks Andy, just thinking of another project for down the road. I have an 87 Ramcharger and a low milage /6 and was thinking of putting them together if I could get an overdrive to work. I like the Ramcharger but the 318 has got to go. 9 to 11 mpgs doesn't work for me as I drive 50+ miles a day round trip.
You need to drop a Cummins 4BT in that!
  Trans leaking like a sieve after parked-couple other leaks. 67RTBlue 12 7,985 08-22-17, 08:08 AM
Last Post: crlush
  Small annoying issue with my Floor shifter - 727 Trans TekHousE 6 3,401 09-02-15, 04:07 AM
Last Post: TekHousE
  Motor Home Trans mike1968rt 9 5,786 03-06-14, 01:52 PM
  Quick shift trans fluid BooBoo 2 3,782 09-22-13, 05:12 AM
Last Post: Sedanman67
