Threads: 67
67440Dodge Wrote:Damned good work Jeff!! Doing work some professional shops would have trouble with (or say "that's close enough")
Thanks Mike!
Threads: 67
Update,
Originally I decided not to do any block oiling system modifications on this engine. I have now reconsidered, so I started reaming out the main oil feed passages (from lifter galley) to 9/32. I will also install a restrictor (drilled freeze plug) in the drivers side lifter galley as opposed to totally blocking it.
I inserted this steel 3/8 rod in the lifter galley to protect it from the reamer (just in case) turns out It wasn't needed and ended up causing the passages to clog up with iron shavings. You live and you learn I guess.
Threads: 67
Threads: 67
After the stains removed -
Here are the detailed emblems reinstalled - I was also able to shine up the side trim some. Not like new but much better than it was.
Threads: 67
Threads: 67
Better pic -
Threads: 67
Threads: 67
I also test fit my valve cover - perfect!
Threads: 67
I read somewhere that if you are going to use a LED for a charge indicator light (which I am) that you have to install a resistor between the + & - terminals of the LED. I bought the required 100 OHM 1 watt resister and soldered it in.
Threads: 67
Update,
Assembly time, first I needed to make a tool to hold the belt drive cam adapter so the bolts can be tightened. It worked perfect
