fuel gage and temp light inop on 67
I check for power with a test light on the back of the gages and one terminal on each gage makes the test light flicker . I cant get it to keep a constant light , like I got a bad connection but no matter how I wiggle the connections it still just flashes intermittenly . The steering colum and dash panal are loose . Do they need to be tight to get a good ground ? Thanks . BooBoo . I,m wrong , I,m getting a flickering light on both terminals on both gages .
Are the lights (for the gauges) not working or the gauges themselves?
The gages are inop . The lights work great . I just hooked power from the positive battery to the temp sending unit and it pegged the gage .
Those two gauges are powered through a voltage limiter. You should look there first. And I do believe the whole cluster is grounded through the dash screws.
Ahhh and where might I find the voltage limiter sir ?
You need to make your own limiter like I did in the picture, Or buy a new board Like I did as well. I fixed one problem and made a new one by breaking off a pin.
My dash works perfect now.
1348
There is a article online on how to make your own... Google mopar voltage limiter upgrade, or just buy the new board with the solid state limiter built right in.. about $150.00 from Classic Industries.
They are still available in your local parts store..
BWD part number R307... GP Sorensen has them also but don't know the part #
Oh man ,,, I da never figured that one out . Thanks ! BooBoo
Here is the one I got from classic industries. Its for a 67 . Notice the solid state limiter on the left side. I had to buy it because I broke off two pins on my old one that I just fixed.
My gages work now, before they did not..
1349
  Worn Fuel Pump Pushrod 67RTBlue 3 18,365 09-05-18, 09:09 AM
  Fuel tank vents Stargazer 11 8,084 08-04-16, 10:28 PM
Last Post: metaldad
  Brake warning light stays on 67RTBlue 7 5,610 06-10-16, 08:55 PM
  Tail Light Bulb Holder NZ 68 R/T 19 9,554 02-04-16, 11:54 AM
  Fuel tank to fuel line rubber hose picture 67RTBlue 12 6,972 01-27-16, 02:25 PM
  Fuel filler leaking cnmsales 5 4,006 12-18-15, 06:01 PM
  Has anyone Added an in tank fuel pump For carby setup instead of standard electric Jpr777 5 3,273 10-08-15, 06:56 PM
Last Post: Drag-Net
  Fuel gauge has me stumped. Billb66 11 7,351 08-28-15, 10:19 PM
Last Post: Billb66
  Fuel pressure of a stock 318 tkarman 2 3,148 05-22-15, 03:26 PM
Last Post: tkarman
