newbie with electrical problems
hey guys. when i come to a stop sign and if i dont two foot it to keep idle up my baby will stall. if the headlights are on the same happens. i do have a fairly lumpy cam so i usually two foot it anyway. i load tested the battery and it is fair but fully charged. Any help with trouble shooting would be greatly appreciated because i HATE electrical issues
Details details. What kind of Mopar? What engine? Single or dual feed alt? Upgraded volt reg?
are you sure it electrical? sounds like it could be a carb/timing/vacuum leak issue.
welcome to the site .....
i talked to another mopar freak at work and he thinks my voltage regulator is fried. I understand this was a problem with these in the day. it a 383 with a single fed alternator. i am going to check the voltage from the alternator to see whats up. all i hope for is something easy and not pulling out the dash. if i wiggle wires underneath the dash the interier lights will dim or brighten
  idle problems Honez 9 6,184 06-29-16, 12:23 AM
  Horn Problems Avenger 7 5,062 06-07-13, 01:11 PM
  Hot Rod mag issue 05/13: A Must Read on electrical issues Hibbing_Coronet_500 4 4,240 03-12-13, 10:13 AM
Last Post: jfreakofkorn
  Electrical issues cnmsales 8 6,430 03-10-13, 11:16 PM
Last Post: cnmsales
  carburetor problems. 67deluxe 3 4,665 01-09-13, 05:31 PM
