brake booster
need a power brake booster with double cylinder for 66. Any one know of a good place to get one?
If you're trying to convert a '66 to a dual reservior master cylinder you are going to need more than just the booster and master cylinder. I'd look for a '67 in a junkyard and take everything from the firewall to the distribution block/proportioning valve.
Last Post: herklots
