NEW PROCESS A-833 TRANSMISSION ISSUE
I have a 1967 Dodge Coronet 440 w/ a New Process a-833 4 speed transmission. It has a serial # of w2349G200631.
The problem I'm having is that in 1st, 2nd and 3rd gear it is making a chattering noise. When I shift into 4th, it pretty much goes away. I have two different people who seems knowledable but are not transmission guys. One says it's the pressure plate in the clutch is going bad. The other guy says it sounds like the main bearing in the clutch is gone? I am not a motor head by any means and would like some advice before I shoot off to the transmission shop. I ask the guys if being low on tranmission fluid, (it's got a slow leak on the reverse plug) could cause the noise and they said no. Also, if anyone has any idea what the cost of doing a rebuild of my transmission vs. going out and finding a replacement. Thanks Mark
If the main bearings are gone, it will make quite a noise in all gears but final drive because there is no load on the bearigs. The main bearings are in the transmission. They can be damages by lack of oil as well. So if the noise you are talking about is completely gone in 4th it is most likely the main bearings.
+1 to what ws27 said.
4264door Wrote:+1 to what ws27 said.
Tim even agrees with my poor freaking spelling/typing LOL
Dern tootins I agree with ur spellink mishtsteaks too...LOL.
  Small annoying issue with my Floor shifter - 727 Trans TekHousE 6 3,401 09-02-15, 04:07 AM
Last Post: TekHousE
  Speedo Issue elevatorman 0 3,060 09-01-14, 04:47 PM
Last Post: elevatorman
  Weird lights issue. Some guidance? cnmsales 37 19,680 03-03-14, 03:14 PM
Last Post: 68 500
  727 transmission issues hammond472 3 4,341 08-22-13, 01:08 AM
Last Post: hammond472
  Transmission swap question Avenger 9 8,031 08-21-13, 02:41 PM
Last Post: duke51
  Transmission Fluid Leak Zaq 1 3,163 07-12-13, 08:45 PM
  Starter Relay / Ignition issue Zaq 9 5,390 06-04-13, 05:33 PM
Last Post: 71_deputy
  Wiring Issue markbob@ameritech.net 3 3,553 05-31-13, 04:42 PM
Last Post: markbob@ameritech.net
  904 transmission pan Coronet 14 13 10,717 05-25-13, 12:43 AM
Last Post: Coronet 14
  Strange charging issue rlsbee 2 3,331 03-14-13, 12:00 PM
Last Post: FRATZOG
