Station wagon tailgate window crank repair
If you have the manual window crank like mine and its getting sloppy, it can be fixed for $1.00. It is better to do this before it is completely shot so you can get the window to operate(trust me I know).
Get the window down and open tailgate, and carefully open window back up while supporting and have something to rest it on ready so it cant fall off track, I used a chair with a cushion. Then take the metal panel off inside to access crank handle nuts (3)7/16 socket. Once unit is off there is a spring steel retainer holding the catch spring in, pop that off as it is probably nasty and needs cleaning, once that is off and out you can see a external c-clip holding the rest together. Take that off and clean up and go the hardware store and find the fiber washers section (plumbing). Grab one same size as original spring washer, mine was a $1.00. About 0.20 thick mine was.
Put it back together with the fiber washer on clip side with some lube and button it up .
Thanks for the tip Andy!
We have a recall on the fiber washer , after many crank's up and down (Lauri works this wagon hard)the fiber washer got sloppy so today I went and got a machinist washer to make a more solid fit.
We apologize for any inconvenience this may have caused. ��
Gee Andy, after all of the time I spent looking for the tailgate on my 66 Coronet 500 2 hardtop and know this recall? Rofl
Was this a voluntary recall or mandated by the NTSA?
  Window fuzzies/furries.whiskers et al TekHousE 51 29,477 11-18-14, 09:27 PM
Last Post: aslbow
  Front window regulator "plastic rivet" work around "Toilet seat hinge" DannyHavs 9 9,444 05-21-14, 11:34 PM
