discoverd oil pressure gauge tucked up under dash...
I found this oil pressure gauge coiled up under the dash and now that it's mounted, what should I be looking at?
Here's a video of it idling and revving a bit (apologies for kid scream at end).
https://www.facebook.com/photo.php?v=691...8556911237
What's normal pressure during idle for 318 poly?
How about during normal 55mph driving?
Where does the "rotating" red mark need to be placed and what kind of "trouble" would I see when driving down the road... what numbers would cause me alarm when driving or idling or whatever?
Thanks in advance!
-Dan
acceptable oil pressure is 10lbs. per 1000rpms. oil pressure will be high when the motor is cold and then lower when it warms up. my cars are usually around 20lbs. at idle and 30-40lbs when cruising and up to temp.
65rbdodge Wrote:acceptable oil pressure is 10lbs. per 1000rpms. oil pressure will be high when the motor is cold and then lower when it warms up. my cars are usually around 20lbs. at idle and 30-40lbs when cruising and up to temp.
Thank you.
  Headliner & dash Kingspagetti 7 2,654 10-15-21, 11:54 PM
  Temperature gauge Avenger 7 6,141 09-08-16, 01:07 PM
Last Post: Avenger
Last Post: Billb66
  WANTED 1965 Coronet 440 red dash pad 4404spd 0 3,113 07-15-15, 11:30 AM
Last Post: 4404spd
  Fuel pressure of a stock 318 tkarman 2 3,148 05-22-15, 03:26 PM
Last Post: tkarman
Last Post: harold prentice
  Dash lighting Avenger 5 5,072 08-04-14, 03:46 PM
  no dash lights, no gas gauge, spooky...... uncledon 43 20,037 06-12-14, 03:11 PM
