Threads: 9
Hi I have a 67 coronet with disc fronts drum rears and no power booster.
im looking at buying one, any suggestions to where to get them, what brands what size.
anything technical I need to know.
thankyou.
Threads: 308
Factory style B-body power brake boosters will require you to either get the firewall plate off a power brake car, or modify your existing one.
I believe theman440 put a A-body booster on his car, hopefully he can chime in and say if any modifications were needed to put it on his car.
If you want to go with a factory style one, then you should get a used one off a car with all the correct hardware. That's the easiest way.
Threads: 9
Thanks for that, it's hard over here in Australia to get parts as there are no spare coronets
