ignition switch
Gotta replace ignition switch. Ordered US50 switch,never replaced one but it came with no key or key hole. Do I just unscrew old key hole and screw in the new one and still use the old keys?? Thanks for any info,BTW I hate Beerelectrical issues!!!!
Todd, get the old switch out in your hand, you will find a little pin. Put the key in, press the pin in while turning the lock. It should come out.
I hope that works and I'm not mixing up the procedure with some other brand ignition lock! LOL
Hey Rich, ok just turn the key left or right while pressing the pin? I haven't removed the old switch yet,and where is this pin? Damn I hate electrical issues,just shoot me ,hang me,whatever, give me a carb to overhaul and I am fine, electrical POS,I don't have a clue,BTW still got your dash you sent me,thanks again man
It practically takes 2 people do this, if you haven't done it before. The body of the ignition must be held securely -(a vise would also work if you don't have a second pair of hands). The key must be put in, turned to the right (same as if you were starting the car), and held in that position. the pin must then be pushed, and while being pushed, pullout on the key as if you were taking it out, but while it is still turned to the "start position". The lock mechanism will come out with the key still in it. The pin that must be pushed is small and located in a cutout "window" that is located near the front of the switch, in the threads that are for the locking ring that holds the switch in the dash. This "window" is only about an 1/8" square. The pin is about the diameter of a pencil lead. The pin is recessed in the window, so you need something small to depress it, you wont be able to push it down with your finger. To put a new one, put the key in it, slide the lock mechanism in the ignition switch as far as you can, turn the key to the right, and push it the rest of the way in. It will be locked in, held by the little pin in the window.
Thanks we got her out and replaced ,not that bad of a job,just the first time I have done this
  Airtemp switch buttons sticking? 67r/t4speeder 9 29,850 11-15-18, 12:57 PM
  Fan Switch and Other Wiring scottys67 13 8,139 08-29-16, 12:11 AM
Last Post: scottys67
  Neutral safety switch Avenger 15 10,001 08-11-16, 02:31 AM
Last Post: RT K_line
Last Post: JohnS
  Pertronix ignition on a poly Avenger 18 9,255 02-05-16, 11:55 PM
  1967 Headlight Switch stonehengeheels 6 4,976 06-19-15, 01:24 AM
  need brake advice... how hard to switch from manual disc brakes to power brakes?? uncledon 5 4,265 05-28-15, 08:30 PM
  Back up light switch location jeffmc 1 3,160 07-13-13, 12:08 AM
  Starter Relay / Ignition issue Zaq 9 5,390 06-04-13, 05:33 PM
Last Post: 71_deputy
