Threads: 21
I have one of" those" questions maybe someone has the answer.while under my car measuring the brake lines i came across a line block right before the rear soft brake line that connects to the T on axle,that has a round switch ontop with 2 wires going up thru wheel well.What Is It?i ve checked my repair manual & the net, did not find.i know cant be a brake pressure switch ??
Threads: 21
Well after some more research, is that the brake light switch? It works off pressure in the line?
Threads: 16
Unplug it and jump it out and see if the brake lights come on.....
Threads: 21
Good idea.worth a try.was hopeing someone was familiar with it
Threads: 6
2 years later, yes it's the brake switch. sorry I haven't logged in for a while
I stopped fighting my inner demons. We're on the same side now.
Threads: 21
roadworthy Wrote:2 years later, yes it's the brake switch. sorry I haven't logged in for a while
thanks I figured it out back then,havent been on for awhile either,LIFE getting in the way
