Bumper Guards -66 Coronet
Hi again!!
Does someone in this great forum know if it's possible to buy Bumper Guards somewhere?
New (are there any aftermarket?), NOS or used - All info appreciated
(Have seen the rubber inserts on Ebay, but not the chrome parts)
Like the looks with these mounted Smile
7901]
Since the picture was taken ... new tires in the back (same as the front tires)...:-)
Best Regards
//Anders
BE&A used to have them, but they are not around anymore. Their twin is PG Classics, so they should have the too.
PG Classic:
They had front and rear bumper guards to Charger 66..
Just want to verify with you - these b.guards are the same as the Coronet?
BR
Anders
MrCoronet Wrote:PG Classic:
BR
Anders
Double check and see if the original part#'s for both cars are the same.
Richard can confirm.
I had an extensive talk with the owner of BE&A on this. He was adamant that the 66 bumper guards are different because a friend of his test fit them on a 67and they didn't fit right.
The bumper shape is identical on both 66 and 67s. So I bought a pair of their 66s and test fit them on, well,...ahhh... quite a few different bumpers on various 66 and 67 specimens. What I figured out was that the problem lies with rechromed bumpers. When they fix dents before rechroming, they alter the shape of the bumper in ways that you will never notice by eye. So if you put a bumper guard on a slightly misshaped rechromed bumper, you'll notice it doesn't fit quite right.
So go ahead and get the 66 ones, they will fit if your bumper is not too reshaped.
We encountered this as well. Our bumpers were originals and straight. The shape of the guards we rounded up were all very similar. It was the cutouts to fit the bumper that varied. NOT saying 66-67's are different. Just be certain before purchasing. Must be other cars that have the same shape guard but totally different bumpers. Maybe make a template at the mount hole of the bumper to have if you run across a good set.
Now the other question...mounting locations on the bumper. Close to center or spaced out? Seen both. Believe inner is correct for a Coronet. Maybe outboard was a Charger?
67RTBlue Wrote:We encountered this as well. Our bumpers were originals and straight. The shape of the guards we rounded up were all very similar. It was the cutouts to fit the bumper that varied. NOT saying 66-67's are different. Just be certain before purchasing. Must be other cars that have the same shape guard but totally different bumpers. Maybe make a template at the mount hole of the bumper to have if you run across a good set.
I've something similar before also. The mounting bolt on the guard is in a different spot than the one taken off.
It's possible that during the production run they changed suppliers, or the design was changed for one reason or another.
Below are the part numbers for the 1966 and 1967 Dodge Coronet, Dodge Charger and Belvedere Station Wagon models for the front and rear bumpers and front and rear bumper guard assemblies. As you will see, some of these parts are interchangeable between various models and model years and some are not.
FRONT BUMPERS:
1966 Front Bumper (aka Front Bumper Face Bar)
1966 Factory Parts Book Section Number: 13-64-3
Part Number: 2533 475
Description: front bumper face bar
Application: (W) Coronet, all
Application: Charger, all
Number Used Per Car: 1
1967 Front Bumper (aka Front Bumper Face Bar):
1967 Factory Parts Book Section Number: 13-64-3
Part Number: 2768 725
REAR BUMPERS:
1966 Rear Bumper (aka Rear Bumper Face Bar)
1966 Factory Parts Book Section Number: 13-66-3
Part Number: 2533 500
Description: rear bumper face bar
Application: (W) Coronet, all except station wagon
Part Number: 2533 514
Application: (W) Coronet, station wagon only
Application: ® Belvedere, station wagon only
Part Number: 2533 502
1967 Rear Bumper (aka Rear Bumper Face Bar)
1967 Factory Parts Book Section Number: 13-66-3
FRONT BUMPER GUARD ASSEMBLIES:
1966 Front Bumper Guards (Chrome Metal Guards)
1966 Factory Parts Book Section Number: 13-68-6
Part Number: 2533 492 (passenger side)
Part Number: 2533 493 (drivers side)
Description: bumper guard, front
Number Used Per Car: 1 of each part number
1966 Front Bumper Guards (Rubber Cushions):
1966 Factory Parts Book Section Number: 13-68-18
Part Number: 2533 494 (passenger and drivers side)
Description: cushion, bumper guard, front
Number Used Per Car: 2
1967 Front Bumper Guards (Chrome Metal Guards)
1967 Factory Parts Book Section Number: 13-68-6
Part Number: 2768 732 (passenger side)
Part Number: 2768 733 (drivers side)
Application: (W) Coronet, all including station wagon
1967 Front Bumper Guards (Rubber Cushions)
1967 Factory Parts Book Section Number: 13-68-18
Part Number: 2768 636 (passenger and drivers side)
REAR BUMPER GUARD ASSEMBLIES:
1966 Rear Bumper Guards (Chrome Metal Guards)
Part Number: 2533 521 (passenger and drivers side)
Description: bumper guard, rear
Part Number: 2533 511 (passenger and drivers side)
1966 Rear Bumper Guards (Rubber Cushions)
Description: cushion, bumper guard, rear
Part Number: 2533 512 (passenger and drivers side)
1967 Rear Bumper Guards (Chrome Metal Guards)
Part Number: 2533 751 (passenger and drivers side)
1967 Rear Bumper Guards (Rubber Cushions)
Hi guys!
Long time since I posted something on the forum.. (but I do read a lot of the threads..Wink
Today I order a pair of rear bumper guards from PG Classics MOPAR 2533 521 (Thanks Richard). PG named them 66 Charger 1199-66R
Hope they will fit nicely ..
They sell to (labeled) Charger 66 Front also but it's wrong!! They are 67 ... be aware! so I skip those..
Goal: Giving a Little more Life to the rear end...:-)
Have a great day
Regards
//Anders from Sweden
Rocket Side Box -66
BR
Anders
  69 Coronet No Hidden VINs Macdon221 1 15,357 04-26-19, 12:34 PM
  Someone in here who owns a 66 HEMI coronet??? MrCoronet 1 18,240 06-29-17, 08:48 PM
  Pictures Wanted of Coronet 66-67 Convertibles and Hardtops MrCoronet 28 16,402 04-18-17, 07:25 AM
Last Post: MrCoronet
  66 coronet 440 4 door booker t jones 30 24,335 10-14-16, 06:06 PM
Last Post: Drag-Net
  No. of Coronet 500 Convertible -66 in Sweden MrCoronet 2 15,296 07-18-16, 07:37 PM
Last Post: j57little
  Correct Jack instruction decal to Coronet 66.. MrCoronet 42 15,193 04-11-16, 02:08 PM
  Tail panel Coronet 500- 66 ...always painted red between the taillights or full chrome? MrCoronet 9 7,319 03-16-16, 07:21 PM
Last Post: Jim 68cuda
  Hemi Coronet 66 - Tell me more about it... MrCoronet 2 4,396 02-25-16, 06:09 PM
  Need help decoding a 8 3/4 axle to a Coronet 500 convertible 66 MrCoronet 9 6,639 02-14-16, 08:30 PM
  Looking for an Optionlist- Coronet -66 MrCoronet 7 5,622 02-05-16, 08:35 AM
