Question regarding tie rod
Looking on rock auto they have a listing for a front inner and front outer. Is this the same as left tire right tire? Or do both sides have an inner and outer?
67 440 4 Door Coronet with a 318 polyblock.
[SIGPIC][/SIGPIC]
Both sides have an inner and outer. One is left hand thread, and one is right hand thread. That way, the sleeve will act like a turn buckle and increase or decrease the distance between the two tie rod ends for alignment.
If you are not sure, take yours apart first to see.
Or, if you are so inclined, order an inner, outer, and sleeve and change the whole thing as an assembly.
A factory shop manual would be a very wise investment at this point.
4264door Wrote:A factory shop manual would be a very wise investment at this point.
Yes it would!!
Is that different from the chilton manual I have online?
[SIGPIC][/SIGPIC]
cnmsales Wrote:Is that different from the chilton manual I have online?
Yes
The factory shop manual goes into more depth than the Chiltons imho. More concise photos, better pictures, etc. My first front end tear down and rebuild I did a long time ago would have gone much more smoothly if I would have consulted the shop manual before attempting the job. I ended up having to take the car to a front end shop to have it done the correct way and the alignment was done as well. It was like a new car again! You can buy the shop manual reproductions on ebay with some searching. I found some repro manuals at auto swap meets too and the nice thing about that is once you have them, you have them forever. They are also avaiable on CD. The old site here before this new one had links to all of that information and if you ask I am sure the links will be posted up again.
I got mine from these folks awhile back for my 66..
http://www.moparmanuals.com
Try this link: http://www.faxonautoliterature.com/Servi...ge/Coronet
Thanks for the link. Will def be getting that if I cant find a torrent. I knew chilton was a rip off before I bought it, but I was in a tight spot and hoped it would be of help. It wasnt, and I knew better. Ah well, I have a log in to the chilton manual for a year for 67 440 if anyone needs to borrow it.
[SIGPIC][/SIGPIC]
  Lower control arm question Piper 2 22 10-17-23, 01:57 PM
  Question theman440 23 2,985 06-02-22, 01:39 PM
  Vin # decode and emblem question. Rcrail 4 3,997 03-07-20, 03:38 AM
  Heater control cables-routing question 67RTBlue 4 4,420 06-16-16, 03:23 PM
  Valve body question tgranthamfd 2 2,771 02-22-16, 02:16 AM
Last Post: tgranthamfd
  Brake drum/wheel stud question rlsbee 13 5,967 02-02-16, 11:45 PM
  Distributor question 67RTBlue 9 6,884 01-09-16, 11:13 AM
Last Post: 1badstroker
  Brake line question-passenger side line hump or no hump? 67RTBlue 2 2,934 01-07-16, 11:12 PM
  67 Coronet power window question Lipers1 8 5,324 10-11-15, 01:47 AM
  New owner - Choke question/FM Converter tuckerboynton 6 4,782 07-12-15, 05:09 PM
Last Post: Redneck
